My Ultra Road Glide . . . just completed
#61
#62
Second, If you look at the picture of the dash, you will see that there are two switches on each side of the ignition switch, much like the Ultra Glide. On the Road Glide there is only one switch on the left. The inner area has the Speedometer Reset switch. I moved it to between the gages, where Harley should have put it and installed the Kuryakyn Double Switch. This made the look better and gave me a clean look without needing to drill holes in the inner fairing for accessories.
When I did the intercom install, I didn't have the speakers on the bike. The location is where the instructions call for. Funny thing is that I was just at the dealer yesterday looking at the pod location. I'll have to figure out how to make it removable because I often take my tourpak off.
This kit gives the Touring Motorcycle without a Tour Pak the ability to have the Passenger connection for the intercom or to have a Detachable Tour Pak and keep the passenger connection. It lists the items in the kit with Harley Part numbers. But the heart of the kit, The Passenger Switch Sub-assembly and the PTT/VOL jumper harness are not available outside this kit and do not have a part number. It has the Rider Headset parts I will not use and will sell separately on eBay. I am not going to put any "Two Sided Tape" on my Fuel Tank! I just wanted the passenger Headset mounted beside the fender. The parts enable me to have the Detachable Tour Pak and still have the passenger Headset hook up. I will add the speakers later without any switches. No CB switch for the Passenger. The only plugs I will need to hide when I remove the Tour Pak is the Lights and speaker plugs. It is much less than the 6 pin and 12 pin plugs that were needed for the two speaker plugs that were used when the head set was on the Tour Pak.
#63
All I need to do now is ride to the dealer and get the system flash so my system will work. I haven't been able to test it yet.
