I love ABS!!!!!!!!!!
Thanks for clearing that up for me. I should of figured it was BS,
The salesmen that sold me my bike told me several times "remember even though you have ABS it wont work if you are in a turn cause the bike needs to be upright so just keep riding straight if you need to stop suddenly" I told him that didnt seem logical and his reply was there was some type of sensor..sheesh....
This is also the same guy that told me not to get a power commander cause they were being stolen from peoples bikes while parked at events and such. he said all it takes is a screw driver and they are in and out with the unit.
Interesting stat. Apparently bikes with ABS are 37% less likely to be involved in a fatal crash than the same model sans ABS.
http://blogs.consumerreports.org/saf...ck-brakes.html
I've had ABS on a couple of my BMWs, and I wouldn't buy a new bike without it. After a while, you forget about the ABS and just get used to your bike not needing so much room to stop. Even on my non-ABS '04 RK, I'm more worried about being hit from behind than I am about running in to someone.
I'm just wondering when one of the anti-ABS forums members will jump in and try to refute the report above!
Stan
