Sure, exhaust, cams tune. You can do all this for close to a thousand. Does the limited come with a hi flo AC? If not maybe not under a thou but not that much over for lots of extra performance.
Sure, but you're better off spending a little more. My Stage 1 ran around $1400. Heat went down, mileage went up, power went up.
Rthomp, If you don't mind me asking, what is you stage 1? I would like some good results when making this investment as I'm getting ready to pull the trigger. I appreciate it!
Am I correct in assuming that if you change the Air Filter and add slipons, you need to enrichen the AFR? If you don't plan big engine mods, why wouldn't a set Xied's work? I'm amazed that these aren't discussed on here more. To me it's an inexpensive way to richen your fuel mixture to a range suitable for good performance. I did the stage 1 se af and jackpot slipons. I bought a set of Xied's for 79.00 bucks and my bike runs great and get's an average of 41 mpg. anything wrong with that????
Fatcat exhaust with a concentric baffle, S/E Ventilator air cleaner, TTS MasterTune. I'm very pleased with the combination.
