2010 Road Glide
I am 5'7" and looking for a set of bars.
I was wondering if anyone knows if
there is much difference between the
two sets of handlebars????
Can't speak to the heritage bars but the +2 sweepers worked out well for me. The angle of the handgrips is very comfortable.
and no, no cable or wire changes was necessary however I'm not happy with my re-routed clutch cable so adding a +4 inch cable to route back through the forks.
otherwise it works fine.
Do a search. a bunch of people commented on the heritage vs. Khromewerks and others.
Very happy with my +2 Sweepers..
I tried a set of heritage bars when I was installing the Sweepers, I liked the look and feel of the +2 Sweepers better... they are close..
I'm 5'7" also.
had no problem re-routing the clutch cable.
There is quite a bit of difference. I troied Heritage bars, not enough reach. I am 6'2" and have a 37 inch sleeve. At 5'7" the Heritage bars may be just the thing for you. I now have the KW+2s, excellent for me.
Are the sweepers any wider then the stock bars???????????
2010 Road Glide I am 5'7" and looking for a set of bars.
I was wondering if anyone knows if there is much difference between the two sets of handlebars????
A search will lead you to many posts on RG bars, including:
