Need help.... Bike wont start after handle bar change
That sounds like my luck. I have an alarm. With kill switch off my red key light comes on but then goes of after a couple seconds. The fuel pump does not come on in off position. If all you did was swap bars it has to be in kill switch connection. I'd take the switch housing off again & start there.
Did you lengthen wires. Remove any fron the connectors? Need to know more about what you did to try to help fix the problem!
did not lengthen any wires only changed the clutch cable. I unplugged the wires and plugged them back in but that was it.
I have a friend at the dealer who gave me advice on several things to check and they were all good. Everybody agrees its in the kill switch but I can figure it out. I even peeled back some of the wire cover to see if i pinched it on the bars by mistake.
Looks like Im driving the car to Laughlin instead of the bike.....
Pinched wire makes the most sense to me.
I didnt disconnect any of the molex connectors but i made sure they were all pushed in just in case.
Well Im pretty frustrated after tearing it down again and not finding the problem I think Im ready to give up now. Will tackle it again when I get back or if I have to take it to the dealer.
Thanks for your time guys i will let you know what it ends up being.
