Notices
NEWB question.
Old 04-20-2010, 03:47 PM
silverbullitt's Avatar
silverbullitt
silverbullitt is offline
Get a service manual, do it yourself. Then you KNOW what you have and what has been done. Man, I would do services all day long for $240.
Old 04-20-2010, 04:12 PM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
If you just got that bike and are not sure of the service history then you should change the air in the tires as well. Stale air in your tires can void your warranty not to mention the rough ride.
Old 04-20-2010, 04:38 PM
Jinks's Avatar
Jinks
Jinks is offline
It's the transmission. Use a transmission/gear oil of your choice. I like Red Line Shockproof, but your choice may be different.
If it's a used bike you should change *ALL* the fluids, & I mean *ALL*! That's right, engine oil, primary, transmission, brake, & fork. It sounds like a lot of work, & unnecessary, but in the long run it'll be worth the effort & expense. If you do it yourself you'll know it was done, done right, & you'll be a lot more familiar with your ride.
Old 04-20-2010, 04:43 PM
Schoondog's Avatar
Schoondog
Schoondog is offline
Never thought about changing the air. Nice one. I was born at night just not last night but I did get a chuckle out of that one.
Old 04-20-2010, 04:59 PM
Haywire's Avatar
Haywire
Haywire is offline
My 06 Ultra classic owners manual says 20 to 24oz for transmission. Checked hot and upright. Not sure if a 99 is the same
Old 04-20-2010, 05:07 PM
Wes10RG's Avatar
Wes10RG
Wes10RG is offline
If you are into wrenching at all you should consider buying a HD service manual and the Fix My Hog DVD's. If you get those 2 items you could afford something like the Redline VTwin oil pack and put some great lube in the holes and still have a few bucks left vs the $240 service.
Old 04-20-2010, 06:39 PM
binkman78's Avatar
binkman78
binkman78 is offline
That's correct - in more ways than one......
Old 04-20-2010, 08:15 PM
jdreed520's Avatar
jdreed520
jdreed520 is offline
Yea the 99 is the same hot and upright.........
Old 04-21-2010, 07:36 AM
Schoondog's Avatar
Schoondog
I did look into it and yes checked hot and upright. Damn rain today is gonna keep me in a car so maybe tomorrow I can check it again. Thanks again for all of the help!!
Old 04-21-2010, 09:54 AM
fladawg01's Avatar
fladawg01
fladawg01 is offline
Default Tranny
If it's clear fluid (looks like water, but thicker) It could be Spectral Synthetic Trans Fluid. This is good stuff. My Indy used it in mine, but i wasn't aware of it until I changed it myself. I then used Redline Shockproof Synthetic. Had I known I would have kept the Spectral, but when I did my change I already had the Redline.
Both are good products. Redline does make it easier on us old guys when trying to see the fluid on the dipstick. Check it while standing upright not on the jiffy Stand. Make sure it's hot as well.
Quick Reply: NEWB question.
