What in-fairing antenna??
Old 04-20-2010, 12:08 AM
RKKY's Avatar
RKKY
RKKY is offline
Been looking for a decent one myself. Don't know why I'm bothering as I always either use a disc I burned or the ipod. Still would be nice to know it worked if I ever wanted/ needed it.
Old 04-20-2010, 07:07 PM
Handlebarmike's Avatar
Handlebarmike
Handlebarmike is offline
Originally Posted by Texas Fat Boy
I've tried 3 different ones, none are worth a crap. The one from streetglidecota worked until I put an amp in. It was getting interference from the power source somehow.
Got the same issue, worked fairly well till the amp went in...
now getting interference/static noise....
even thru the auxilary w/mp3 player
Old 04-20-2010, 07:32 PM
flight's Avatar
flight
flight is offline
None!!!!!
Old 04-20-2010, 07:37 PM
dudleydoright151's Avatar
dudleydoright151
dudleydoright151 is offline
5th Gear
Default Kragen special
I just installed am amplified antenna under the fairing on my 09 ultra classic. Bought it at Kragen 15 bucks with military discount. attached it to the back of the stereo above the wiring harnesses and ran the 12vdc to the cigarette lighter power wire. Works great and half the price of the name brand ones and even the ones on ebay. check out the parts store best bang for the buck.
Old 04-20-2010, 07:40 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
I have the inexpensive one from E-bay in the detachable fairing on my Road King and it works pretty well. For local stations it's very strong, for things farther away, things fade, but then FM signals are not not as strong as AM anyway. Weatherband? never could get that good a signal. But, for the money spent a good deal.
Old 04-20-2010, 08:15 PM
Coolhawg6622's Avatar
Coolhawg6622
Coolhawg6622 is offline
I have tried them all and NONE work no where near as good as the hard mount on the rear......And the most expensive, dakota digital was the worst!! Run the JM now and am not impressed,,,,,,,I will stick with listening to my MP3......
Old 04-20-2010, 08:39 PM
sidetracked's Avatar
sidetracked
sidetracked is offline
i went to radio shack and picked up a motorola plug (3.50), use some wiring from my gargage door security thing i had laying around (it has two strands). I put the wire into the plug, then split it and wound some to hang on each side of the faring. even in the garage the reception was great. sorry i did not take pictures. some friends of mine did the same thing except they used speaker wires for the antenna.
Old 04-20-2010, 09:07 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
I am not a fan of powered antennas. So I did this with parts from Autozone.
https://www.hdforums.com/forum/touri...orks-well.html
I suck at adding links from this forum.
Maybe someone can search WI Bob+antenna for me.
Old 04-20-2010, 09:25 PM
bdp's Avatar
bdp
bdp is offline
Originally Posted by maxflhx
I had a Tune Trapper, worked fine when the faring was off. Buttoned up didn't get reception fer poo. Used it as a paint stir. I went back to the whip.
X 2 on the tune trapper, i just gave it away the other day. Guess its ok if you live in a big city and never leave.
oakspeed
Audio Systems
09-13-2016 08:38 AM
RC07ultra
Audio Systems
15
09-12-2016 11:12 AM
M16pilot
Audio Systems
11-28-2015 08:14 PM
scomike
09-04-2013 07:53 AM
SubZer0
04-16-2006 02:32 PM
Quick Reply: What in-fairing antenna??
