Cleaning White Walls
Old 04-18-2010 | 09:36 PM
Colby45's Avatar
Colby45
Default Cleaning White Walls
Hey yall just wonderin what the best way to clean the white walls on my RK would be? Thanks
Old 04-18-2010 | 09:38 PM
surfcitybum's Avatar
surfcitybum
I use Mr. Clean Magic Erasers. Work great.
Old 04-18-2010 | 09:51 PM
Yachtman's Avatar
Yachtman
Ditto the Mr. Clean Erasers. Fantastic, and they don't scratch the white wall.
Old 04-18-2010 | 10:00 PM
MarineBagger's Avatar
MarineBagger
Also use the magic eraser. Works well, but the erasers get pretty chewed up. I get about two cleanings out of an eraser, and there are two erasers in a pack.
Old 04-18-2010 | 10:16 PM
ehans's Avatar
ehans
I just use Simple Green and elbow grease, and not much of the latter.
Old 04-18-2010 | 10:17 PM
david christopher's Avatar
david christopher
purple power and a SOS pad
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Hit the Magic Eraser with Shout! laundry stain remover first and it will be a bit easier, although the magic erasers do get chewed up. You don't really need to press hard. Keep wetting the eraser and wringing it out.
Old 04-18-2010 | 10:26 PM
Cokie's Avatar
Cokie
+20 on the Magic Eraser
Old 04-18-2010 | 10:34 PM
PNSHVL's Avatar
PNSHVL
If you do a search first you can get the answer to a lot of your questions. Try Wesley's tire bleach cleaner, spray it on, use a stiff brush, then just rinse off.
Old 04-18-2010 | 10:39 PM
Snakeeyes Cody's Avatar
Snakeeyes Cody
Default Cleaning White wall tires
best product Is Westly Bleche Wite tire cleaner! Trust me!
Quick Reply: Cleaning White Walls
