Zummo 550 mount
Like AlaskaAviator said, you should be able to get that standard 1/4 20 U-bolt at any hardware store.
If not, I've got the U-bolt and a couple of spare acorn nuts that came with the Zumo stored in its box. I can send them to you if you need them.
On the other hand, if you aren't going to be using the spacers for the clutch mount, I could use them. I'm using a stack of washers after the spacers went bouncing into the ditch in Virginia a couple of years ago. Long, sad story...
