...... so, what kind of light pattern do these driving lights throw out onto the road ?
They are not one of those patterns like the Driving Lights. It is not a straight beam that is far reaching with nothing on the sides. It is more of a wide pattern in front. I have not had any fog but I believe that it should help. At a distance it appears to be a spot of light without being obnoxious. I use these at night instead of High beam. and high beam in the day time.
The switch is wired to enable the lights to be on even it the High Beams are on but not without the ignition enabled.
I had those on my bike but I didn't use them much since I installed HIDs at the same time. After several months I just removed them as they had a short in them somewhere and every time I turned them on a fuse blew.
I had yjose on my bike but I didn't use them much since I installed HIDs at the same time. After several months I just removed them as they had a short in them somewhere and every time I turned them on a fuse blew.
