How much HP should I expect?
How much HP should you gain and torque when you get the SERT and Stage one a/c then Dyno done to your EGC? I had it done today, The bike runs much smoother and has good acceleration through the gears it also has some back popping when letting off which I expected a little bit with the new pipes.
It went from 73.82HP and 74.83 torque to after dyno 74.49HP and 75.78 torque. Is this normal, Good or bad. I'm not much on reading these charts the service guy tried to read it to me but acted sort of like he didn't have much clue either.
RE: How much HP should I expect?
You must be saying the bikes equipment were the exact same and the diff in numbers is just the result of dyno tune. If this is the case your numbers will not change a whole lot as the teck is making sert changes basically on the exhaust wand results as to rich/lean settings. This in essence will make your engine more efficient and run smoother. If these numbers reflect any performance parts upgrades you should expect larger positive changes for your money.
So if I'm reading this right when you get a stage one upgrade (SE air cleaner, SE slipon's, and the moco download) I should be in the upper 60's on HP I've always wondered how much diff it would make. Mine was already done when I bought it never rode a totally stock TC
