Help with oil pressure !!
OK a couple of days ago I went to the dealer to get a new rear tire and to pick up oil to change when I got back home.I saw the price of the HD SYN
$14.00 a quart (ouch)and thought maybe it's time for a different oil.After much reading here I decided to switch to MOBIL 1-V-Twin 20/50 fully synthetic,which I got from advanced auto for $7.99 qt.Now comes the issue,
I have been using HD Syn since 1000 mile service,now have 38,000 miles.I changed the oil and filter and noticed that the oil pressure did not come up too good when I first started up.(18-20)psi.Normally when I change it it comes right up to 32psi.Today I took a pretty good ride and at cruising speeds it still only reads about 18psi,the bike has always read around 30-33 psi when riding.
Occasionally today, I would see the gauge fluctuating up and down (12-18 psi) and this when I had the cruise on at a steady speed.At idle it's reading about 6 psi at idle and when I hold the throttle at 22-2400 rpm it still only reads about 16-18 psi.At one point today it did go up to 33 psi but didn't stay there more than a minute or two...
Is there a difference in these 2 oils,as far as pressure goes, or do I possibly have something wrong.
ANY HELP WOULD BE GREATLY APPRECIATED ,
Mark
Mark
Have you checked the cam tensioners? I had oil pressure reading like yours and discovered the tensioners were shot. I am still chasing pressure issues and I have replaced the tensioners, oil pump, cam plate etc... The tensioners may have lodged a peice of material in the oil pressure relief valve. I plan on flushing some of the oil passages in the next day or so when I change the oil. BTW, I also run Mobil 1 V-twin.
P.S. I just took advantage of the sale Advanced Auto Parts is having on Mobil 1. $7.99 a quart. If you buy more than $100 online you get an additional 15% off. I ordered and payed online and picked it up at the store. Approximately $6.80 a quart.
Neil
RDMC
Neil
RDMC
As far as checking the gauge,can I check it with a mechanical gauge?
Do they make a mechanical gauge for the touring bikes,I've never really liked the electrical ones?
Cam tensioners ???Not sure what to do there?I've read many many posts mentioning Cam tensioners and even asked once if this was a problem with the 88tc but never got an answer to that.
The way the gauge was acting erratically up and down I thought maybe an electrical problem of some sort.(or hoping)
Just seemed very odd that the problem didn't start till changing the oil, probably just coincidence though.Thanks Again,
Mark
Mark
Many posts here about that.
Could just be a coincidence with oil pressure change and using a different oil.
