Transmission Oil: Redline Heavy or Amsoil Severe Gear
I have been reading a lot of threads lately on Redline Heavy with Shockproof for the tranny. Yesterday I decided to go on a hunt for it locally and couldn't find it. I want to try this stuff, but don't really like the idea of using a product I can't find locally.
I was able to find Amsoil Severe Gear Oil in 75-140. I haven't heard much about this oil on the forum, but evidently they a pretty proud of it. They wanted $22 a quart at the shop. I passed.
But, I would be more inclined to go with the Amsoil from an online supplier (around $15) if I could at least find the stuff locally if I ended up really needing it.
Anyway, has anyone used both of these products???? Any difference between the two? Or should I just suck it up and order a case of Redline for a good bit cheaper?
Im running the redline shockproof in the primary, and redline 70w80 MTL in the tranny. I think I ordered mine from summit, they were pretty reasonable if I remember, its been about a year. I may switch over to Mobil 1 vtwin in the tranny on my next change as I have 3 cases of it...
ETA: Previously my indy had put amsoil in all three holes. I like the redline slightly better.
I have never used the Amsoil gear lube, but have used the amsoil 20w50 engine oil in my transmission. When I switched to Redline Shockproof I could not tell the difference. Many people have reported big improvements with Redline Shockproof, But the only improvment I saw was it was easier to see the oil level on the dipstick. I would use whatever is readily available.
I had the amsoil gear oil and did not notice much difference from the HD formula. I dont know much about the redline. I went with the Spectro 6speed platinum trans lube and noticed a huge difference. Right off the shifts were smoother and the 5th gear wine was a lot more quiet. Here is a link http://www.spectro-oils.com/products...n/hd6speed.asp
