First time changing brake fluid..nervous & requesting help.
I was always taught that anyone can make a vehicle "go", the real trick is to make sure it "stops"........therefore...
.......I've never messed with brakes, they just make me nervous.
After a lot of reading, I bought this brake bleeder kit. (See pic)
Problem is, even after doing a bunch of reading I still don't understand the EXACT procedure to change out the brake fluid.
I'm not even sure how to set up or use the kit I bought.
I know this is going to be a no brainer once I am educated, I need to learn this.
'06 Ultra, DOT 4.....Two front master cylinders and one rear.
I would so much appreciate step by step instructions if someone would be so kind?
It's OK to talk to me like I'm 5 years old.......because I can't afford to screw this up.
Sorry for being so needy & Thanks a bunch.
BTW, yes I read my service manual, but it seems they assume you've done this before, pretty vague.
