Factory Dunlop's milage
Old 08-07-2006 | 01:44 PM
capt42a's Avatar
capt42a
Default Factory Dunlop's milage
I was wondering what kind of milage everyone is getting out of their factory dunlops. Also list your tire pressures. I got 8,600 out of my first rear tire at 40 psi, still good on the front tire, with 38 psi.
capt42a
Old 08-07-2006 | 01:55 PM
Mr Wonderful's Avatar
Mr Wonderful
Default RE: Factory Dunlop's milage
Do a search on this subject.......it's been flogged to death. But I think you'll find the average for the rear is 11,000 miles and the front is around 28,000. 38 psi seems to be the norm.....some run 40. Never wait until they are near-slicks........tires are cheap.
Old 08-07-2006 | 02:01 PM
MACK's Avatar
MACK
I get about 20k on the front -22k and about 10-11k on the back. RUN 38/40 ALL THE TIME.
06ALULTRA's Avatar
06ALULTRA
11,000 rear front still good
Old 08-07-2006 | 02:28 PM
huffhuff's Avatar
huffhuff
you can increase your rear mileage by not using your rear brake every time you apply brakes. anticipate stoplight changes, pull the clutch in a coast up to the light using the brakes as gingerly as possible. you really only need the rear brake for near panic stops and maybe in a parking lot at very slow speed where the front brake can throw you off balance. the new MU85s have deeper tread and are going to almost 15K now. if you can find someone who can fill your tires with nitrogen you can expect 15 to 20 % more mileage too as they run cooler. heat is the real enemy of tires at highway speeds.
Old 08-07-2006 | 02:33 PM
Neckball's Avatar
Neckball
15,023 on the rear. It should have been replaced a few K's miles sooner. I'm at 21,900+ miles on the front, checked it this weekend and the tread is at 4/32-5/32. Pressure is 36 front and 40 rear on the Dunlops. With the Metzler on the rear now I run 44-45 psi in it.
Old 08-07-2006 | 02:38 PM
navyman's Avatar
navyman
I got 16,000 out of original rear tire. I have 21,000 miles on front with a lot of tread left. It is no where near worn out. I run 40 rear and 36 front.
Old 08-07-2006 | 03:13 PM
billnourse's Avatar
billnourse
I usually get 10,000 on the rear and twice that on the front. The rear on my new EG Classic just went 11,500 and still had tread left, but we were leaving for a long trip and so I changed earlier than I normally would have.
Regards,
Bill
Old 08-07-2006 | 07:05 PM
stglideblk's Avatar
stglideblk
i have 12300 on mine and not to the wear bars, but getting close. most of my riding is two up and we have taken two trips with the bike loaded, and i alone am 300 lbs. run 38 to 40 psi.
Old 08-07-2006 | 07:38 PM
wireman2511's Avatar
wireman2511
im at 5000 and down to wear bars what tires are reccommended for replacement
Quick Reply: Factory Dunlop's milage
