08 RKC Brake Light Issues
Old 04-08-2010 | 07:53 AM
scootervtx's Avatar
scootervtx
6th Gear
Default 08 RKC Brake Light Issues
On my way home my check engine light came on. I checked the code and it is showing PO572 ( brake switch low ). The brakes work fine but I do not have any brake light from the hand or foot lever. All other lights are working fine. My guess is fuse or bulb. Anyone have any ideas? All info and advice is much appreciated.
Old 04-08-2010 | 05:15 PM
scootervtx's Avatar
scootervtx
6th Gear
ttttt
Old 04-08-2010 | 07:38 PM
izzy's Avatar
izzy
if you did the brake light/tail light conversion, unplug the conversion and plug it in as it was originally and try it. It's worth a shot.
Old 04-08-2010 | 08:17 PM
EdwardK's Avatar
EdwardK
My rear brake light switch failed. First brake light issues then it started squirting brake fluid and lost the rear brake. The dealer said they had several failing the same way. Mine didn't throw a code though.
Briguy1
Electrical/Lighting/Alarm
02-09-2015 07:10 PM
SteveB FLH
10-18-2012 05:12 PM
Sallyman
06-27-2011 07:12 PM
VirtualNorm
05-05-2011 08:06 PM
AZCHOKESTER
01-10-2008 11:34 PM
