Fluid leak off clutch cable
04-07-2010, 06:33 PM
I have a drip coming off of my clutch cable. I has to be Tranny fluid because it is heavy and smells like 90wt. I had my Indy do the bar swap which needed a new cable. Can't find the source of the leak. Could it be from where the cable goes into the tranny? What would be the cause?
Thanks
04-07-2010, 06:37 PM
There is an oring where the cable threads into the cover. see if it's loose but do not over tighten. Also check bolts on the cover
04-07-2010, 07:05 PM
this could be dumb but, did they oil the clutch cable? it may be excess which will dry out
just a thought
04-07-2010, 07:14 PM
Quote:
Originally Posted by
deadbug
just a thought
My thoughts too.......Not too say all mechanics would, but if they worked
on your bars they maybe lubed your cable.
04-07-2010, 07:26 PM
Sounds like your indy needs to go back and check his work!
04-07-2010, 07:35 PM
Not sure if they oiled the cable or not...
Hog-doc,
I already talked to him about it. He told me if it kept it up that he would try a new cable.
04-07-2010, 09:11 PM
There is an O-ring on the end of the cable, PN 11179.
04-07-2010, 09:32 PM
it's also pretty common to cross thead the cable in the transmission housing. Mine came from the factory this way. I then cross threaded it myself when I upgraded to braided cables. While out on a long ride, I tried to tighten it some and it broke off...
Long story short, it would not surprise me if:
a) it's cross threaded
b) the bolt has broken off in the housing
04-07-2010, 10:02 PM
I think it's clutch cable defect.
Scudda
09-29-2015 01:20 PM
Premont Harley
10-30-2011 08:41 PM
Bluesrider
03-15-2009 02:23 PM
YellowHawk
12-16-2007 05:40 PM
bg5377
07-30-2007 01:45 AM
07 ,
cable ,
clutch ,
davidson ,
fluid ,
glide ,
harley ,
king ,
leak ,
leaking ,
leaks ,
leaky ,
oil ,
road ,
sportster
