my first oil change, whats needed?
ok folks i always have dealer change my oil so want to start doing more on my bike myself since i work on my car and truck and mowers anyway. what all do i need to do it right on my 09 street glide? i know question sounds stupid but ive not changed oil myself on this bike so i wana get it right.
Factory service manual
oil for motor, trans, and primary
new o rings for trans and motor drain plugs
New sealing washers for derby cover screws and either new O ring or gasket for derby cover
oil filter
Torque wrench
Bike lift to level bike
funnel
Set of Torx fasteners for derby cover screws and primary drain screw
Other than that, just the usual assortment of sockets, ratchet, allen wrench (for transmission fill plug) oil filter wrench, oil drain pan, rags, and a big hammer.
oil filter
Torque wrench
funnel
1FLTRI4ME is saying buy a shop manual for your ride. That will tell you all you need to know about changing the oil. The manual will tell you to remove the derby to change and refill the primary fluid. Ive since been told there is no need to do that, that you can fill it via the inspection plate (if your bike has one).
