Charging Problem
Charging Problem
So last weekend my street had the engine light and battery light come on. I stopped be my mechanics and he checked it out and said the statur was good and the regulator was bad. I picked up a new one at the stealer and put it on and the same lights are on and the gage still says it's putting out under 12, . Any ideas?? Does it sound like the new regulator is bad, does this happen often, and if so how do I get the dealer to replace the defective part? They are about 65 miles away and I dont want to take the bike down there.
Having 2 bad regulators is rare. First make sure your battery is 100%. If voltage is now it will not charge correctly. Make sure the ground for your regulator is good. After that you will need to check all your connections making sure a pin has not come out of a connector. If all that fails you will need to start with checking the stator and going from there.
