tire manufacture wives tail true or false?
Old 04-05-2010 | 08:53 PM
Lawdawg's Avatar
Lawdawg
Cool...thanks again.
Old 04-06-2010 | 06:51 AM
Notgrownup's Avatar
Notgrownup
Originally Posted by piasspj
Having different brands is OK.
You don't want to run drastically different tires for example radial and Bias. There are some combinations that will make the bike handle funny in some situations.
I believe this to be BS also...The lateral movements or flexes on the radial VS Bias is different but the only really noticeable difference would be on trailers...When they are in-line you shouldn't be able to tell...well at least on a Harley anyway...Maybe running a sport bike at very high speed...I ran a Bias on the rear and radial on the front for over 10k and never noticed anything different and this is in a variety of roads...
Old 04-06-2010 | 07:37 AM
BLKBAGGER's Avatar
BLKBAGGER
I used to mix Dunlops and Metzlers on my bike for years. Never a problem.
Old 04-06-2010 | 07:49 AM
VETERAN75's Avatar
VETERAN75
I have heard that said, but I think that goes back to older bias tires. I've seen plenty with mix match tires and no problems these days.
Old 04-06-2010 | 08:15 AM
emwolb's Avatar
emwolb
it's a wives tale. you can use whatever tires will fit, some guy was mentioning recently about wanting to use a car tire on his. a real no-no. mixing brands does not harm anything at all as long as they're the correct size and aired up properly. sorta reminds me of walking into one of my friends shops and seeing a couple of car batteries sitting on 2x4's. that's a big old wives tale. used to be for the old rubber cased batteries with tar as the sealant on the top. not to worry about your tires though.
Old 04-06-2010 | 08:16 AM
dog155's Avatar
dog155
The word Crock! come to mind?
Old 04-06-2010 | 09:09 AM
frenchbiker's Avatar
frenchbiker
It's complete baloney.
Old 04-06-2010 | 07:38 PM
Lawdawg's Avatar
Lawdawg
Thanks for all the help, it is time to replace my rear tire. I recently had my front replaced under warranty so I didn't want to replace both...thanks again.
Old 04-06-2010 | 08:04 PM
Crusing's Avatar
Crusing
I don’t know for sure, but I have a buddy who is running different front and rear tires. At 80 mph he is experiencing a serious wobble. He is not sure if this is due to the tires or is it is possible an alignment issue.
Old 04-06-2010 | 10:30 PM
buttman's Avatar
buttman
The first thing he needs to do is check tire pressure.......
rcevil
03-18-2012 05:20 PM
Tinsleytown
05-09-2011 06:10 PM
Lawdawg
10-02-2010 06:56 AM
Mark
07-13-2010 09:21 AM
Madgoat
10-06-2006 06:45 PM
