Warped Rear Rotor???
So I was riding today and in a slow turn I applied a little rear brake and it seemed to catch and then release then catch. So when I had the bike up on the jack cleaning it later today I spun the rear wheel and sure enough the wheel would spin free except for one spot where the rotor seemed to rub agaisnt the pads. So I looked down at the top of the caliper where you can see the pads and rotor and spun the wheel real slow, it seems in one small spot the rotor is warped and rubs the inside brake pad.
So the question is... is this normal? slight warp of the rotor? It seems strange to me because the amount of the rotor that rubs is so small, it's just maybe 1/2 inch if that, I would think for that rotor to warp it would be much more.
Also anyone else ever have a rear rotor warp on them?
Thanks
Thanks
If you could hook up a dial indicator to the rotor, you could get a more precise measurement of how much it was out.
I've never had a bike rotor warp but I have had it on a car. In that case, I think it was just a batch of bad rotors on the car (it was new). The dealer replaced it under warranty.
martin10
General Topics/Tech Tips
06-16-2016 05:18 AM
