Notices
Road Glide Carrying Capacity
Old 04-01-2010, 02:51 PM
slowrollin's Avatar
slowrollin
slowrollin is offline
Default Road Glide Carrying Capacity
Anyone know how much weight the MOCO says the Road Glide can carry comfortably. The EG Classic and Ultra are supposed to be 474Lbs. The dealer says it should be the same, even with the shorter shock in the back but that just doesn't sound right to me.
Old 04-01-2010, 03:08 PM
Pumba11's Avatar
Pumba11
Pumba11 is offline
I can't answer that confidently, but only the 2010 RG's have the shorter shock.
Old 04-01-2010, 06:54 PM
emwolb's Avatar
emwolb
emwolb is offline
the information is all in your owners manual. do yourself a favor and familiarize yourself with it.
Old 04-02-2010, 02:33 PM
honorsdaddy's Avatar
honorsdaddy
honorsdaddy is offline
Not only is it in the manual, but the GVWR is on a sticker on the frame.
You could probably get a little bit more on the FLTR than on the FLHTC and FLHTCU as they have the added weight of the trunk.
Old 04-02-2010, 02:35 PM
Emonster6x's Avatar
Emonster6x
Emonster6x is offline
Build your bike to a "117" and you can haul a ton of crap! I know a guy who did this!
Old 04-02-2010, 02:37 PM
rstekeur's Avatar
rstekeur
rstekeur is offline
How does that help the load capacity ?
Old 04-02-2010, 03:41 PM
slowrollin's Avatar
slowrollin
Thanks for the advice. I would do that if I owned one of those bikes and had one those owners manuals. I own a softail and I'm interested in the bikes I'm asking about.
Old 04-02-2010, 03:46 PM
slowrollin's Avatar
slowrollin
Thanks! I didn't actually know it was listed there. I'll go back to the show room and take a look at that. Thanks again!
Old 04-02-2010, 05:44 PM
Kingo99's Avatar
Kingo99
Kingo99 is offline
Location: Chicago & Door Cnty. Wi. Sarasota Fla. In winter
Hey Slowrollin, real helpful bunch on this forum, huh. I've several simple questions treated like they just did to you. Rather than help a guy, they jump down their throats in an attempt to make a fool out of the answer seeker. According to my owners manual a 2010 RG. gvwr is 1360 lbs, the weight of the bike is 783 lbs the difference is 577 lbs. That's your load potential. I'm outa here, this joint sucks.
Old 04-02-2010, 06:35 PM
pavin's Avatar
pavin
pavin is offline
Hey Slowrollin, i just looked at my OM for a 2010 RG. the gvwr is 1360 lbs and the weight of the bike is 783 lbs if my math is right that leaves 577 lbs. hope that helps.
Quick Reply: Road Glide Carrying Capacity
