My bike is a 2000 RK with the MM EFI. I am starting to gather parts for a carburetor conversion. I have a good idea on what all I will need including some part numbers. The only thing I am having a problem deciding on is the ignition. The bike is stock now but as the money comes I will be doing, Rineharts, air filter and eventually a big bore kit with heads and cams. What would be a good ignition for my wants/needs? Thanks!
Thats a great write up and helps a ton! I really cant justify spending almost $400.00 on an ignition alone right now, although that one is bad a**. What are some other options that are reasonably priced?
