17 or 18 rear wheel???
I am about to purchase a set of custom wheels but i torn between a 17 and 18 inch rear wheel. I know a 17 will keep you just about the stock height but will an 18 raise you up that much? I am pretty short so that is the only reason i would be torn between the two sizes.BTW this is going on an 09 street glide.
I had the very same question when I was about to order my wheels. I went with a 17" rear wheel with a 200mm tire. I'm lowered in the rear so it made sense to go with a 17". I didn't want to rub plus from what I understand, the 17" 200mm rear tire is something that all HD dealers carry in stock where as the 18" 200mm is not a common stocked item.
IMHO--this is the way to go -- I have an 18 put a 200 on it; it wobbled so bad I had to buy a new tire out of state. Had to pay out of state prices and labor. Others have had success with the 18/200 but not me--now I am back to 18/180 and $400 lighter in the wallet
17" 200mm here... I called Costal Moto and Eastern Performance both before I made the choice of 17" or 18" and they both pretty much said the same thing...
If you go with an 18" rim you should stay with a 180mm tire, if you want the wider 200mm tire you should go with the 17" rim. They both said they thought a 200 tire was to wide for the 18X5.5 rim... they said the 17X6.25 was alot safer so thats what I went with.
