04 Roadking-tipped it, now it wont run-Help!
I have a 2004 Harley Roadking Classic, I went riding today, oppss, and tipped it over onto the crash bars, sitting at a light. It was still running, I stood it up and started down the road, it started out ok, just for a 1/2 block, then started acting like it was starving for fuel, I coasted to a stop. It cranks over, I can hear the fuel pump cycle, when I turn on the key, but it won't even spit.
I took off the breather cover and sprayed gas in it, and it fires perfect,,, so for sure not getting fuel,,,
But I hear the fuel pump, cycle and then stop when I try to start it and then stop.
Injectors not getting fuel?? Pump not pumping enough pressure?
I have never had a problem with this bike,,, running perfect!! I tipped it over, just to the crashbar, so basically barely tipped it,, I was sitting at a light,, no impact or anything like that..
Totally puzzled,,,,,,
Can you help????
Can you help????
Thank you all for the ideas,,, This sucks, LOL
I tried the ignition switch,,, didn't work, this is weird, I can hear the fuel pump come on and then cycle off,, I try to start it, and it cranks, then when you let off, you can hear the fuel pump cycle again and shut off. but still nothing.
If I spray gas in the air breather, it fires up and runs, then starves out.
I did disconnect the fuel line were it goes into the injector body, I turned it on and cranked it, there is no high pressure, just fuel running out - gravity.
The down side of fuel injection, I guess!
A buddy was sitting on my bike and lost his balance and started tipping it onto the engine guard. Saved the bike from falling but alittle gas came out and bike stalled. Error was on the display. Turned off bike for a couple of minutes and kicked him off it. I got on and it started right up. Doesn't really help in your situation. Did you pull your plugs and check them out to see if they are getting spark? Check your fuses for a blown fuse?
What Dog said. I had the bas on my 99 roadking go out on me. Everytime I hit a bump the dang thing would shutdown. I would pull over, take my left rear bag off and flick the sensor. It would be fine until I hit another bump. Found out that it was not on correctly so that it didn't take much for the "angle" to be off. Once I put it on the correct way it worked fine. That would be the first thing I would check as well.
