Setting-up the PCV-AT for mileage and cooling
Old 07-08-2015, 09:21 AM
87gtNOS's Avatar
87gtNOS
87gtNOS is offline
Originally Posted by Impala_ss
Interesting. So I would think that the best bet is to have it learn a few times until a satisfactory correction rate to complete a decent base map. Then to leave it on to act as a basic closed loop system?
Ultimately for 09+ you want a Power Vision and tune the Lamda (by changing the tables for the volume of air going into the motor).
BUT, I cannot afford to change to PV.
With PC5 and Autotune, the best I gather is the Harley ECU in OPEN loop and will still add/subtract fuel based on LOAD. It's in OPEN loop because of the O2 optimizer plugs. In OPEN loop it does not use input from the OEM narrow band o2's, instead it defaults to 14.6 to 1 or something like that, but still works with all the other sensor inputs.
When the AT (autotune) is ON, you are, in a sense, in CLOSED loop, as the PC5 is live tuning the bike to the set A/F tables. So it's OVER RIDING the ECU (base map + any LOAD added/subtracted fuel!)!!!
So I am trying to get the definitive answer to this: AT on=no load added fuel, AT off=ECU can add fuel based on load....wouldn't AT OFF be better once all AT'ing is done?
Sublime1
12-03-2010 01:47 PM
jlange322
06-02-2010 10:38 AM
NAUIdvr1
Fuel Moto / Jackpot Mufflers
04-26-2010 03:07 PM
Rambone1570
01-23-2010 06:57 PM
Puttnutt24
11
04-30-2009 01:24 AM
Quick Reply: Setting-up the PCV-AT for mileage and cooling
