Cig Lighter Keeps Blowing Fuse
Yea, that should be an easy find. And most likely it is the actual lighter I would bet. The way to check would be to ohm from the wire terminal on the rear to the housing on the lighter. (I would remove it or at least unplug it electrically.) Then ohm between both wire terminals on the rear of it.
IF it ohms with resistance, but not a dead short. Then check the power wire in the bike, (AGAIN without power on) to ground and see if it's shorted.
If you don't have a spare, buy one. Nothing to lose, you'll have a spare for the saddlebag.
