Runs strong, Way too much heat...
How long should I expect to leave the bike with him? Do you know what he charges or does it vary based on the time involved with the dyno? You stated that you spent 8 days with him...was that just you learning or was it the time involved with tuning you bike or both. I looked at the website, it looks like he is also a training location.. Maybe I should give his number to the dyno tech that has been working on my bike..
A previous poster said he spent 8 days with Doc. That's because Doc teaches tuning (i.e.: the 8 days). Doc quoted me an approximate cost of $425 to dial in my build using my already installed tts Mastertuner. I'll be riding down from Tallahassee to get this tune done in a day (by appointment).
Wow ,way to much Dyno Time,sounds like they are having big problem trying to dial it in. Usually for the first 500 to 1000 miles after a complete top end rebuild they will run hotter but not like what you are going thru.The timming must be off and I would now worry if the cylinders are scoored up too.Too try to help out make sure that you are not restricting any air flow around the engine.
sounds like you found a tuner who was more experimenting with your bike rather than being experienced. i found an absolute wizard in tulsa which is the nearest city to me. 70 miles away, and he does precise tuning. i've recommended him to a few other guys around eastern oklahoma, and they're very pleased with his tuning, as am i, obviously. no heat issues with my motor with.10.5 pop up pistons and .579" lift cams. do yourself a favor and find a great tuner who is experienced.
Sounds like Doc knows what he is doing and in no way trying to Hijack this thread but thought would mention this Guy for ones in North FL/So GA area .. High Performance Cycles in Lake City, FL www.hpcycles.com .. 90% of this guys work is Dyno's and He does it well ..
