Short antennas
RE: Short antennas
I have the shorts on my '06 Ultra and I bought them on E-glide goodies. The radio antenna works as well as the stock one. I don't use the CB so I couldn't comment on that except that I heard that the reception would suffer alot with the short. The ones I have are solid black (no flex) approx 9" and fit right on with no problem.
RE: Short antennas
I just cut my FM antenna on my 07 Ultra, to 12", and I think I cut it a bit too short. My reception isn't as good now, so I ordered a EGlide antenna. I took off the CB antenna since I don't use that anyway - if I'm going to use it, I'll just put it back on. If you do that, be sure and don't key up the CB, I understand it's bad for the radio to key it up without an antenna. Freedom Cycles Reno also has short antennas for both FM and CB radios.
If you cut your antenna, leave it longer than 12". Like the carpenter said, "I've cut this dang thing three times, and it's still too short."
RE: Short antennas
I have been thinking about this too. I just went to Ebay and did a search on motorcycle antenna and the solid black shorty ones seems to be popular. I cut 5" off my 07 antenna so far and it's still good. Think I will do 2" at a time and keep checking the range out so I don't have to say what the carpenter said........[sm=smiley20.gif]
RE: Short antennas
You guys are something else.
I use to be a real fanatic about thing being symmetrical. It use to drive me up the wall if thing didn't look evenly spaces or balanced looking.
It is a little aggravating with the antennas on my '03 Ultra when I go to put the cover on it, so I can appreciate your situation and wanting to have short antenna but I just can't give up the reception.
RE: Short antennas
I got mine here:
http://www.freedomcyclereno.com/
Use to be able to just buy them on-line, now it looks like you must call them.
Just 15" tall, work easilly as well as the original. Just the radion, never tried the CB. I replaced mine after I had my second whip just snap off!!!!
Joe
Joe
