Redline Shockproof Heavy in the tranny
Old 03-23-2010, 09:31 PM
SICKBAGGER's Avatar
SICKBAGGER
SICKBAGGER is offline
Default Redline Shockproof Heavy in the tranny
I did the swap from Syn 3 to Redline Shockproof heavy in the transmission like Dawg suggested. WOW what an entirely new silky smooth feel!!!!! It just slips through the gears effortlessly and much more quiter first gear is still the roughest but improved dramatically. I will do it forever now!
Old 03-23-2010, 09:34 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Ive been telling people that for 6 years now!
Old 03-23-2010, 09:36 PM
SICKBAGGER's Avatar
SICKBAGGER
You have definately been trying to set em straight I just can't beleive how much it imrpoved it Doc
Old 03-23-2010, 09:37 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
SICKBAGGER's Avatar
SICKBAGGER
Doc, What do you run in the primary?
Old 03-23-2010, 11:11 PM
alphadog001's Avatar
alphadog001
alphadog001 is offline
Yep Redline is a noticable difference in tranny
Old 03-23-2010, 11:16 PM
cap5369's Avatar
cap5369
cap5369 is offline
doc it would have been nice if you would have filled us in......and joined 6 years ago, it would have saved alot of confusion....
Old 03-23-2010, 11:19 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Still F+, for now. I will be going to ATF when I change my primary cases.
Old 03-24-2010, 06:42 AM
iclick's Avatar
iclick
iclick is offline
I've had good luck with the heavy gear oils I've used, and have now settled on RL SPH. I used Royal Purple 85w140 for a while, which worked as well but costs $4 more per qt. than RL in this area. It has Belray 85w140 in it now simply because of warranty work done on the tranny (mainshaft bearing) and that's the only heavy gear oil the HD shop had in stock. Since it was free I took what they had. It is also working very well, but I'll go back to RL SPH at the next oil change.
I'm still using fossil 20w50 in the primary, which has worked very well--but I'm thinking about changing to ATF Type F after I run out of the Castrol GTX I have on the shelf.
Old 03-24-2010, 07:09 AM
gibby122's Avatar
gibby122
gibby122 is offline
alright... Ill give it a try when I hit 5k, just had the 1k done last week & running Syn3 now. Better than what was in there from factory thats for sure. Ran syn in all 3 holes in my last bike. no probs. But for some reason this tranny seems louder...?
Quick Reply: Redline Shockproof Heavy in the tranny
