Nearing the end on DIY tire changing
Scrooge,
I think I see where you're coming from.....it's not about the tires or the bead breaking.
It's about getting to a physical state where these jobs that you have truly enjoyed for years are beginning to be beyond your abilities.......
I fear that most in life.
I'm 48 and very much a DIY'er....and think about the day when I won't be able to turn a wrench or swing a golf club.
It's inevitable & something I don't like to think about.......but.....yes, that time will come whether I like it or not.
I just hope that you have received a lot of enjoyment out of it over the years.
Cheers to you.
Cheers to you.
I bought a pack of dyna beads, but I had to use so much soap salution to get the bead to set I was fearful of having a sticky mess inside the tire. I opted out for ballancing with a piece of 3/4" all thread with a sealed bearing on the ends, bearings resting on jack stands. The tire changer I built will have the ballancer brackets in place for next tire swap.
I'm 56 btw. Some of you have a few years on me, but I spent the last 28 years waiting to die litterally. The bike got me off my fat ***, and gave me a reason to move again.
Scrooge,
Cheers to you.
Cheers to you.
mounting and removing tires is not hard with the right tools, I built a square out of 2 X 4's with a cross brace in the middle , drilled a hole in the center of the brace and screwed in place a 3' piece of 1/2" threaded bar from Home Depot, carpeted the top of the wood, used scrap wood and carpet scraps, 1/2" bar cost under $5, then bought a www.no-scufftiretool.com for $87, followed the directions and it's a snap, hardest part is the stop & go bead breaker, it works well but a little slow, if I changed tires often I'd upgrade, but at 1 or 2 tires a year it's not worth it
