View Poll Results: Tire pressure - which do you run at?
Voters: 216. You may not vote on this poll
Tire Pressure-where do you run yours? Manual or sidewall?
Received 29,072 Likes
I believe at max pounds, there would be hardly any flex and it would ride very stiff......But, to each his own.....
Maximum pressure on the tire sidewall: This is different for a tires recommended tire pressure. This number is the maximum cold pressure necessary to carry the maximum load for which the tire is rated.
Maximum Load Limit & Air Pressure
Maximum Load Limit - "635 kg [1400 lbs]"
This indicates the tire's maximum load-carrying capabilities when the tire is inflated to its maximum inflation pressure, as indicated on the sidewall. Max load is based on standards set by the National Highway Traffic Safety Administration (NHTSA)
Maximum Air Pressure - "300 kPa [44 psi]"
This indicates the maximum operating inflation pressure of the tire. It does not indicate the manufacturer's recommended inflation pressure, nor does it indicate the proper air pressure based on the vehicle the tire is mounted on. This category is also based on NHTSA standards.
Note - Some tires are marked 'Extra Load', 'XL', or 'RF' (for reinforced). This simply denotes that the tire's indicated maximum load and air pressure are higher than a standard load tire.
As per above, the maximum load number tells you the maximum amount of weight a tire can support when cold. Exceeding either or both (max pressure and/or load can result in catastrophic failure of the tire).
