highway pegs
Depending on your leg length... if you're long in the leg, you may like the long angle extensions,(my buddy who is about 6'-4" and long legged likes the long angle) If not.. then either the short angle or the 360's. I had the 360's on my 05...even with them angled in a bit after awhile I felt like I was having to reach around the lowers. If you remove the lowers for summer riding ... no problem. I tried the long angle... I just couldn't get them in a comfortable position that did not interfere with me getting my right foot from the rear brake pedal to the ground. So I went with the short angle... and like them very well...I think they will give you more position options. I have a 33 inch inseam. Mater of fact, I need to take some pictures of my long angles and put them up for sale.
Leadman - Here are some shots of my setup. Probably a little higher than you are looking for but think the hardware I have would achieve your goal.
I bought the Kuryakyn Switchblades (4443) and their offset footrest mounts (7996)
The first pic shows the mounts. I've got them straight but you can lower them by two inches. If you slide the clamp down the guard bar slightly you will get pretty close to the height of your floorboard I think.
The second pic will give you some perspective.
Hope this helps your decision!
peg location on engine gaurd
I've been moving my HD 360's all over the place trying to find the most comfortable position. Seems like when i get a comfortable one it is awful close to the brake area and i'm afraid that it could get in the way of moving my foot in and out of that area. Anyone having similar issues? I clamp them in front than i move them to the back of the bar just can't settle on a permanent location. Also, i like to have the peg hinge turned on an angle towards the back a little so they will get pushed up if i brush close to something and that kicks them back near the brake petal area even more when their up.
