Oil Temp Guage
Old 03-20-2010 | 10:56 PM
soos's Avatar
soos
Having the gauge is not so much a matter of oil temperature accuracy as much as it is a means for you to monitor your oil temps at any certain time under any certain conditions. Oil temperature is a relative thing. Sitting side by side with another bike, you will not always have matching temps. Use it to monitor your bikes operating oil temps on short runs and long highway trips. If it is 65* and you are at full operating temps, you will have a certain oil temp reading. If it is 85* and you are at full operating temps your oil temps will be higher. if you are in stop and go traffic your temps will rise and if you are moving your temps will drop. It's all relative. If your scoot is running at peak performance and the oil temps are in the 180* to 220* range you are running good. Don't obsess over it.
Old 03-20-2010 | 11:02 PM
twodollarbill's Avatar
twodollarbill
Originally Posted by BAGGERNATE
How do you do that when your on the road?? I have one of those infered temp finders too, but can only use it while off the bike. Does me no good at 60 mph.
NATE
Old 03-21-2010 | 10:22 AM
Ultra89Rider's Avatar
Ultra89Rider
Originally Posted by captjon37
The accuracy of those gauges is debatable.
That is why you should only use them as a guide. Not as Gospel.
Old 03-21-2010 | 01:49 PM
iclick's Avatar
iclick
The accuracy of those gauges is debatable. I find them almost as useless as the air temp gauge. I understand that there are many that like them but i will stick with the hand held infrared for its accuracy and the ability to measure the temps of every part of the bike in seconds.
My fairing-mounted gauge matches my IR thermometer within a few degrees. I agree with Soos that the need for an exact temperature should be less a priority than seeing relative relationships. I know what my oil temp should be related to the gauge reading, and can react accordingly when it goes outside my comfort zone. I will say that it is my most-used gauge, next to tach and speedo, and I wouldn't want to be without it.
Old 03-21-2010 | 01:57 PM
PistonPuller's Avatar
PistonPuller
Originally Posted by HD101st
i have a 09 FLHT and i am having a hard time swallowing spending $139 + parts that i need to put a temp guage on does anybody have other ideas on how i could save a couple of dollars
Don't buy one. That will save you money. I have never had a temp gauge on the 3 Harley's I have owned. Never had a problem with overheating oil temp. Sure it may be peace of mind, but for me piece of minds means not having to worry about what the temp should be every time I look at the thing. Again my
Old 03-21-2010 | 06:55 PM
HD101st's Avatar
HD101st
Thanks for all the input i will put one in eventually but other things need to come first.
Old 03-21-2010 | 07:29 PM
themensh's Avatar
themensh
Originally Posted by twodollarbill
I picked up a handheld inferred temp gauge for about $25 on ebay.
Very accurate and I can use it on all my bikes.
Do you remove your dip stick first? How does it tell the oil temperature?
Old 03-21-2010 | 08:12 PM
Sadist112's Avatar
Sadist112
Oil temp gauge is nothing more than a sanity check. I got this one for $45 bucks on ebay and it works great!
http://www.autometer.com/cat_gaugede...id=3578&sid=61
See pictures, fits just fine, the second pic shows the slight gap which is really not noticeable when sitting on the bike. This one comes with every you need but the wire which is 50 cents at home depot. Don't waste your money on a $140 gauge, that's a lot of beer! Go with the beer, ESB should be coming out in two weeks!!!!
Attached Thumbnails Oil Temp Guage-2.jpg   Oil Temp Guage-3.jpg   Oil Temp Guage-1.jpg
Old 03-21-2010 | 08:28 PM
captjon37's Avatar
captjon37
NATE
How long does it take you to get off that bike?
Old 03-21-2010 | 08:41 PM
oldhippie's Avatar
oldhippie
Default Thumbs Up!
Originally Posted by lionsm13
Rodger McEwan Oil Temp Gauge
http://www.speedsupplies.com/accesso...asp?item=42570
is what I and many others on this site have.
You can't really tell it's not stock.
Matches the 09 SG's gauges.
Look it up on this site.
Lots of threads on it.
I have this too and really like it. I think it's got less range, but hence more accuracy that the HD. Mine sits right at 200'F with the stage 1 and Jag oil cooler.
