Air pressure
Old 06-02-2005 | 09:27 AM
Meinbmw's Avatar
Meinbmw
Default Air pressure
What is everyone using for adding pressure to the rear shocks? Does Harley sell a low pressure pump, or are there readily available pumps out there like at bicycle shops, etc.
Old 06-02-2005 | 10:14 AM
billnourse's Avatar
billnourse
Default RE: Air pressure
Harley makes a pump, complete with air gauge. Do not use regular air pumps unless you want to blow a seal.
Regards,
Bilkl
Old 06-02-2005 | 02:25 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
I run 15 psi in forks (I have a 2000) and 5 in rear solo and 15 with rider. The Harley air pump works very well. Progressive makes one that is more expensive but looks just like the Harley one. All dealers should have one. Can't remember the price but somewhere around #30.00.
Terry
Old 06-02-2005 | 03:04 PM
Pelonz's Avatar
Pelonz
I usually run 10psi in rear for solo and jack it up to 15 for 2up. Got a Progressive pump many years ago , works fine.
Old 06-02-2005 | 03:14 PM
swb's Avatar
swb
Here is the part number and link:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
It works well for me.
Old 06-02-2005 | 03:15 PM
Blue SOG's Avatar
Blue SOG
I ditched the crappy air shocks for Progressive's 440 shocks... Better ride, better handling and no air pump.
BTW, need a air pump? I'll sell a slightly used HD pump...
Old 06-02-2005 | 08:16 PM
sporty12's Avatar
sporty12
Bill,
Good advice on the pump, but I don't even know any seals that well.
Russ
Old 06-02-2005 | 09:41 PM
motochris's Avatar
motochris
ORIGINAL: billnourse
Regards,
Bilkl
On that note......A penguin is driving through a small town, when his air conditioning suddenly goes POW, and quits working. He stops at a local repair shop, they tell him they'll have it done in no time. He heads down the street for some ice cream. Enjoys himself a big vanilla cone, thoroughly getting it all over his face. Waddles back to the repair shop, the mechanic walks up and says "Well, it's broke alright.....looks like you blew a seal." The penguin starts to wipe his face quickly..."No, no, it's ice cream......it's vanilla ice cream!"
Old 06-03-2005 | 01:05 AM
Retired_Ted's Avatar
Retired_Ted
Be aware if you have a quick disconnect kit installed, the pump may not seat on the air pressure fitting - there is a fix if you need it. Just let me know. I use 8 psi solo and 15 psi dual.
Old 06-03-2005 | 10:51 AM
HDF Tech's Avatar
HDF Tech
Ted
See you've been there too!
Ozark Joe
EVO
01-18-2017 02:25 PM
Kyle C Kirk
12-28-2013 05:57 PM
Toliverpeterson
09-01-2012 10:44 AM
Hurleybird
03-08-2010 03:05 PM
67xlch
01-01-2008 08:38 PM
Quick Reply: Air pressure
