FINALLY got rid of the squeal!
Being in the automotive parts industry and servicing many front end and brake shops, the noise you hear is vibration (from fit and finish). I had a little over 1,000 miles on my bike when the noise monster hit me. I removed the rear pads cleaned all mounting parts and applied the the brake pad gum on the back and used caliper grease on the pins. 6,000 miles on bike now with no squel from OEM pads. Caliper grease and brke pad gum is availible at any parts house.
I haven't tried the caliper grease. I have used the brake anti squeal from Permatex, (auto supply), that lasts for a few hundred miles but the squeal comes back. I'm going to go back to the OEM brakes and try the HD fix. Usually just about the time I begin to feel good about my latest fix the noise comes back. That's why I'm asking how long has the fix lasted when guys say they have fixed the squeal.
Thanks for all the replies though. I'll keep checking this post along with anything I try that seems to finally work.
Ratkiller
Was beginning to think I was cursed with squealing rear brakes forever. I had switched to Lydall Z brake pads and thought this would stop my squealing, didn't help. All the Lyndall pads did was squeal and make my rotors shine like having been polished. Having been through every other fix known, I went back to HD Brembo brakes. What I didn't know was Harley has since made changes to the replacement pads. First off the locator pin is larger diameter and second is the paste that comes with the kit.
The paste is put on using a temporary mask (with 2 holes where the pistons are) that is put on the back side. Then you apply the paste to the area in the mask where the 2 holes are, using the supplied scraper to remove the excess paste. Remove the temporary mask and carefully reinstall pads being carefull not to get paste anywhere else. Went for a ride and no more squeal and the brakes worked like new. Also saw that my rotor where the pads run had started to lose that polished look and after a few more miles the rotors looked like they should look.
Have to say, I am very happy to have solved this squealing but, I am disappointed that the expensive Lyndall pads did not solve the squealing, in fact they polished my rotors while giving less stopping ability.
Funny thing was the HD dealer parts guy didn't seem to know about this kit and tried to give me the stock OEM brake pads. When I insisted that there might be a fix for the problem he looked and saw that there was another number for the upgrade.
So far so good.
Ratkiller
My 09 ultra had a squeal it quit when I was leaving a rest area somewhere in South Dakota... when I realized I left HER at the rest area I had to go back, the squealing got worse. true story. You can take them any where in the world after a while they start to forget about the trip, But leave them in a rest area one time and they will remember that forever.
Lyndall responded and they are sending me replacement pads for front and back. They said they should be lasting longer than 4,500 miles. They said I need to check alignment on bike, pistons and caliper. I told them everything is checking out good. But let's see how long these new ones last.
