touring tire pressure?
Old 03-19-2010 | 09:45 PM
ThaGlyde's Avatar
ThaGlyde
Default touring tire pressure?
I just got my tires changed and the shop said i might need to put some more air in there because as the tire breaks in, it expands some more. Im goin on a trip early and i need to know what my front and rear tire pressure should be. They are factory spec 16 inch rims.
Old 03-19-2010 | 09:52 PM
outlaw0013's Avatar
outlaw0013
On an 06 the book says 36 front and rear solo 40 rear if two up
Old 03-19-2010 | 09:53 PM
Airborne06's Avatar
Airborne06
Look on the tire...it will indicate the maximum p.s.i. for the tire.
Old 03-19-2010 | 10:01 PM
S1 4 Life's Avatar
S1 4 Life
Nice bike
Old 03-19-2010 | 10:05 PM
Dan1127's Avatar
Dan1127
36 front 40 rear all the time. But i might go up a little in the front I noticed some wear around the edges
Old 03-19-2010 | 10:19 PM
TheShrink's Avatar
TheShrink
Yep, check the sidewall for max PSI. I run 38 front and 40 rear with my Michelin Commanders.
Old 03-19-2010 | 11:01 PM
rogerfromco's Avatar
rogerfromco
I am pretty sure the sidewall markings are MAXIMUM, not recommended tire pressures. Look in your owners manual for stock tires.
Old 03-19-2010 | 11:41 PM
1plumr1's Avatar
1plumr1
my manual says 32 front and rear unless 2 up or loaded. Has always worked for me.
Old 03-19-2010 | 11:46 PM
BLKBAGGER's Avatar
BLKBAGGER
I always run the max on the sidewall.
Old 03-20-2010 | 12:02 AM
oldbagr's Avatar
oldbagr
Filling to the max rating on the sidewall will leave your tires overinflated once they heat up while riding. The manufacturer's recommended tire pressure is a cold rating (before bike is ridden) and gives consideration to how the bike is set up, as well as the original wheel and tire sizes for your specific bike as well as whether you will be riding solo or two up. Bottom line: Check you owner's manual.
Quick Reply: touring tire pressure?
