touring tire pressure?
Old 03-21-2010 | 01:14 PM
Markymannn's Avatar
Markymannn
Originally Posted by themensh
(oops.....37....let some out....oops, 35....add some......damn 39....let some out. Frig! 37......let some out. 34.....GRRRRR!)
chuck the mensh
You got that right! Although I doubt 1-2# makes much diffrence
I run 36 & 36; 36 & 40 two up
  #32
Old 03-21-2010 | 01:24 PM
Ronp42's Avatar
Ronp42
Account Retired
The size of some women I've seen on the rear of Motorcycles,I don't think running a few extra pounds of air is going to hurt the tire.
  #33
Crusing's Avatar
Crusing
I have always run the pressure recomended in the owner's manual in my D402s without any issues, i.e. cupping, wear. etc.
  #34
Old 03-21-2010 | 02:50 PM
jjohnson77536's Avatar
jjohnson77536
Default 40r 38f
Tend to run 40 r and 38 f. Check pressure before you ride. My front tire tends to lose air over a few weeks (down to 35)
  #35
Old 03-21-2010 | 02:53 PM
OnTheFence's Avatar
OnTheFence
40ish / 40ish. I also run synthetic air. Normal air breaks down in Harley tires.
  #36
Old 03-21-2010 | 09:46 PM
S1 4 Life's Avatar
S1 4 Life
Don't tell me to do homework! I said putting 50 Psi in a tire with a rating of 42 MAX! I wasn't talking about the 50 Psi max tires, it's printed right on the sidewall.....pay attention
Originally Posted by BLKBAGGER
If you did some home work you would know that some of the Metz have a 50 psi rating.
And for you guys that are saying use the manual, What if the bike now has tires that use a different pressure from stock? You are giving bad advise and don't know what the hell you are talking about. Blow outs are caused primarily from under inflation. When loaded you should always run the max pressure stated on the sidewall of the tire. Running the max pressure gives the tire it's highest load rating.
  #37
Old 03-21-2010 | 10:34 PM
fxdxruss's Avatar
fxdxruss
I thought that the rating on the side wall referenced total weight load capacity of the tire (who's ever tire) at this pressure which is the max press. of the tire carring that weight !
So wound't you find weight of m/c, weight of cargo & passengers . Knowing that and using the info on the tire come up with a psi rating close to what the tire need for the weight they are carring.
2007 FLHTCU gvwr 1259lbs weight shipped 808lbs
front gawr 500lbs
rear gawr 827lbs
total 1327lbs this is what the axle's are rated to carry not m/c
Factory Dunlops OEM tire front 783 lbs @ 40 psi
rear 906 lbs @ 40 psi
total 1689 lbs
manual tire pressure all model solo 36 psi front/36 rear, Rider & Pass 36 psi front 40 psi rear
Bike with fluids and stuff and rider 1120lbs solo seems that the owners manual would be close to the weight on the tire vs pressure. I would think that adding a passenger would not put all the added weight on the rear tire so I would up the front as well probablly to 38psi.
Russ
  #38
Old 03-22-2010 | 12:35 AM
2whlr4life's Avatar
2whlr4life
Arrow RoadGlide
Originally Posted by RKKY
I have found 38 front/ 40 rear works the best for me on the SG.
When I got a new air compressor for my garage I played around with it. I ranged from 36-40 on the front & 36 to 42 on the rear within a summers day. I really didn't notice any big differences. I'm a believer in keeping them on the upper end of the range with my Metz's. Other bikes I've owned have been different though. I might drop the rear tire 2 lbs in a long rainy ride, it helps me avoid skidding the rear.
  #39
Old 03-22-2010 | 01:16 AM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
I run 40 front 42 rear !!!
  #40
Old 03-22-2010 | 03:48 AM
frenchbiker's Avatar
frenchbiker
38F-42R on my 09 Ultra. Riding 2 up 99% of the time.
Oh and make sure you use HD Certified Air, otherwise you'll void your warranty.
Quick Reply: touring tire pressure?
