Clutch adjustment....got a quick question.
What do you guys use to make your clutch adjustment at the primary?
It doesn't seem likely that you can get a regular wrench at the locking nut with out stripping the crap out of it. Nobody likes stripped nuts so is there a specific tool or any little tricks that you guys and gals can share?
I tried a regular open ended wrench but no dice. I guess one of those new goofy craftsman "dog bone" wrenches might work because the opening will allow easy access to the adjustment screw but I figured I'd ask the experts.
Thanks,
Tony
Thanks,
Tony
They make a open socket set sold at sears or the ratchet wrench set with flex head that would be perfect for that but i would have no other use for it so i just use a open end wrench with no problem slipping or stripping. I like the dog bone idea and now i have a use for one. Always look at them just wondered what the hell i would use it for. Now i know.
sweet, keep'em coming....thanks guys.
What size is it. I don't want to crack the cover with out a new seal to check. LOL
I guess it will have to wait till the next time I change the primary fluid. I wanted to check the clutch while I was in there yesterday but I am not gonna get another gasket unless I have issues.
again-thanks guys.
again-thanks guys.
again-thanks guys.
again-thanks guys.
Can get a Lockit Socket like attached or simply take a long 11/16 socket and grind two flats on it so a box wrench fits (this is what I did) if you don't weld.
