Clutch adjustment....got a quick question.
Old 03-24-2010, 10:50 AM
mongomark's Avatar
mongomark
mongomark is offline
Just make sure you do the adjustment cold, per the manual.
Old 03-24-2010, 11:00 AM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,735 Likes on 1,302 Posts
+1 important, I drain the oil hot and adjust the clutch the next AM. If you're having trouble getting the jam nut put it in gear and apply the back brake
Old 03-24-2010, 11:30 AM
jdreed520's Avatar
jdreed520
jdreed520 is offline
I bought a ratchet set that lets a bolt pass through it open all the way through and i slide a long allen into it......
Old 03-24-2010, 12:21 PM
mnskip's Avatar
mnskip
mnskip is offline
The tool kit that came with my '08 had the socket in it, check your kit before you spend the money. Worked for me.
Old 03-24-2010, 12:33 PM
soundman's Avatar
soundman
soundman is offline
I welded a rod on a socket that acts as a handle. one less tool to have to hold onto.
Old 03-24-2010, 01:54 PM
pounder35's Avatar
pounder35
pounder35 is offline
Good Idea I bet it is in there and I've been scrambling for box wrench lol
Old 03-24-2010, 02:19 PM
ftanner's Avatar
ftanner
ftanner is offline
Originally Posted by Toe Knee
What do you guys use to make your clutch adjustment at the primary?
It doesn't seem likely that you can get a regular wrench at the locking nut with out stripping the crap out of it. Nobody likes stripped nuts so is there a specific tool or any little tricks that you guys and gals can share?
I tried a regular open ended wrench but no dice. I guess one of those new goofy craftsman "dog bone" wrenches might work because the opening will allow easy access to the adjustment screw but I figured I'd ask the experts.
Thanks,
Tony
Harbor Freight offset box-end.
Old 03-24-2010, 02:44 PM
Glyder's Avatar
Glyder
Glyder is offline
Originally Posted by chasswartz
vice grips on a deep socket also works.
bingo!!!!
Old 03-27-2010, 11:06 AM
Toe Knee's Avatar
Toe Knee
Toe Knee is online now
thanks for all the replies gentlemen. adjust cold. got it. already knew that though....don't ask me how! LOL
a mistake that will only be done one time!
Old 03-27-2010, 11:15 AM
Dionicio's Avatar
Dionicio
Dionicio is offline
Originally Posted by DPete
I welded a nut on a deep socket so I could hold the allen wrench thru the center of the socket and turn the welded on nut with a wrench
Did the same thing , works great!
Quick Reply: Clutch adjustment....got a quick question.
