recently installed a Wet Sounds amp and speakers. Install was not difficult but I am having troubles getting it to sound decent. I am hoping it is me as opposed to the product. Anyone have this set up and have the amp dialed in so it sounds good
There is a process on how to set the gains on the amp, but I can't recall what it is. Search the forum for that or for the instructions on the Arc Audio amps - very similar. Or contact Aaron at www.throttleupindustries.com
Location: LexVegas, KY...home of fast wimmen & beautiful horses
....yep, that WET SOUND amp should totally rock 4 u. Double-check your specs below.....it's EZ to dial in. Just be sure the button below the ground wire is pushed "in."
thanks for the info. Understanding the Arc amp and the wet tunes amp are basically the same set up instructions are similar. I am getting closer to happy, but a pain none the less to keep removing the faring every other day to make adjustments, but as I said I am getting closer to happy
I have an ARC and run the gains fairly low - maybe 25% at the most. Set them too high and your you won't be able to use your AVC. I set my AVC at 2 bars and it works great.
