Seals/Gaskets/"O" Rings
Whenever I tell my dealers parts dudes to give me the "O" Rings or primary gasket for oil changes they always give me this package that contains more crap than I need at a cost of $14.95?
Sometimes they'll just kick in the "O" if I tell them I'm just changin' the engine or tranny fluid...but when I mention Primary gasket out comes the PACKAGE from hell.[:@]
Is there anywhere I can go to get just the ONE or TWO items I need? NAPA? Autozone?
RE: Seals/Gaskets/"O" Rings
We have an 03 EG and here are the individual P/Ns for the typical items used for an oil change:
1 63798-99A Oil filter (chrome)
2 11105 Transmission and oil drain plug o-rings
2 11132 Transmission filler plug o-ring
1 34906-85D Inspection cover gasket (primary)
1 34901-94C Primary cover gasket
1 25416-99C Clutch cover seal
However, I have found that the "kit" is cheaper than buying each item. Here's what's in the kit P/N 17361-05 (Service gasket kit)
Here what is listed for the gasket kit:
2 O-Rings . . . 11105
1 O-Ring . . . .11324
1 Clutch Cover Gasket . . . .25416-99C
1 Inspection Cover Gasket . . . .34906-85D
1 Inspection Cover Gasket . . . .60567-90C
Of course, if all you need are o-rings....I picked some up at my local hardware store. Hope this helps.
