How would you clean off over-spray
I have some overspray on my bike from someone spray painting in the garage (that's another story so let's not go there)... anyway, the bike paint is fine and looks fine, but is rough to the touch. Has anyone cleaned off any slight overspray like this? If so... how, and any hints would be helpful. THANKS!
Car Polish... wash first then use car polish, put a little between your index finger and thumb so you can feel the grit. Then follow up with wax.
Don't spend too much time in one area so you don't scratch the surface.
Good luck!
Paint thinner then wax sometimes works... test a small area first...
Good luck!
Good luck!
Good luck!
Also, if it's on the paint, did you check the chrome and such? Some Mother's polish will make that chrome come back sweet.
TL
Thanks... I'll give the cleaners was a try first and then progress as needed. The paint is still great (09 ultra), it just has a non-smooth surface feel like a grit is on it... it needs a light cleaning... but more than soap and water, I have cleaned it the best I can with a non-abrasive. I appreciate the help... never had this problem before and hope I don't again :-)
TL
