stock shock oil replacement ?
Old 03-14-2010 | 12:55 PM
fasteddiee122's Avatar
fasteddiee122
Default stock shock oil replacement ?
hey guys i was wondering how to replace the oil in the stock rear shocks , have been told you can do it with a syringe ,how much and what kind of oil should i use ? thanks for the input
Old 03-14-2010 | 01:57 PM
qtrracer's Avatar
qtrracer
Talking
Sorry, the best way I found for my riding style to help the ride on my 08 FLHX, was to drain the oil out of the shocks into my waste oil container, then very carefully, take the stock shocks and keep them as far away from my bike while replacing them with aftermarket shocks.
Old 03-14-2010 | 02:03 PM
BoomerBob's Avatar
BoomerBob
This is the best and most correct way to tackle this.
But to answer the OP's question; turn upside down and let drain for a day or two. Using a lightweight oil, like the stock 5 weight or for a firmer more controlled feel, use 7.5 or 10 wt. I used synthetic trans oil the last time I did it and it worked pretty well. I used a large syringe, like you might use to inject butter into a turkey with, to fill them up with 11 oz in each shock.
Old 03-14-2010 | 02:33 PM
maineultraclassic's Avatar
maineultraclassic
You can also build a jig that will pump the oil out. Just install them upside down and compress them a few times, that will get all the oil out. Then turn them over and measure out 11oz of new oil and slowly install it with a turkey baster, you'll have to pump it a few times to make sure the oil get's past the dampers.
I'm going with 10wt suspension oil when I do mine this spring, stock is 5wt.
Steve
Old 03-14-2010 | 02:38 PM
Eddy G's Avatar
Eddy G
Honda dealers sell 5, 7 1/2 and 10 wt "Shock" oil. The stock harley shocks are made by the same people who make the oil. I used the 7 1/2 wt last time I did it and it worked great.
I'm running the shorter street glide / HD 12" lowering shocks on my Electra Glide classic with out any trouble.
I used a barb style fittings in the shocks and pumped in the oil (I think the mentioned 11oz is correct) in with a rig I use to bleed the brakes.
Take a plastic soda or power drink bottle drill in a barb fitting to the cap and run a plastic hose from the bottle to the shock. You can pump it in easy enough a little at a time.
There's a video or detailed pictures of it on the v-twin form
Old 03-14-2010 | 04:07 PM
DocDyna's Avatar
DocDyna
Default Fork Oil ??????????
I have checked with the Honda shop up the road all they have is Fork oil. I was wanting to switch to some 10wt but did not know if Fork Oil was the right oil for my air shocks on Ultra. Anyone have the lowdown ???
Thanks
Old 03-14-2010 | 04:17 PM
BoomerBob's Avatar
BoomerBob
Thanks
Yep. Forks are shocks.
Old 03-14-2010 | 04:35 PM
fasteddiee122
thanks guys thats exactly what i wanted to know !!!!
Old 03-14-2010 | 04:41 PM
fasteddiee122
that is pretty funny
Old 03-14-2010 | 04:48 PM
twodollarbill's Avatar
twodollarbill
Harley Fork Oils......
E is 5 wt
B is 10 wt
SE is 15 wt
SE heavy (racing) is 20 wt
Quick Reply: stock shock oil replacement ?
