Flush mounted LED Tail light questions
Old 03-12-2010, 02:32 PM
turbo38sfi's Avatar
turbo38sfi
turbo38sfi is offline
Default Flush mounted LED Tail light questions
Looking for someone that's done this before and can lend some advice.
I'm looking at the following manufacturer, Lambert Enterprises. Looking for advice specifically on size recommendations..my thoughts are to go with their 1x8 " LED Strips. They sell flush mounting ABS buckets as well as lens too. My question is more around load equalizers and such... I'm going to give them a ring as they seem like they are quite the experts to see what they recommend.
I would like to use them as running/brake/turn signals all in 1.
http://www.lambertenterprises.com/custom.html
What are your thoughts?
Old 03-12-2010, 02:52 PM
WhiteGoldSG's Avatar
WhiteGoldSG
WhiteGoldSG is offline
I run Native Custom Baggers set up..check out my thread pics, but as far as load equilizers, a Badlands run/turn/brake controller will do the trick. that is what I have..
Old 03-12-2010, 03:01 PM
turbo38sfi's Avatar
turbo38sfi
I'll check it out. Is it s plug and play module?
it a
Old 03-12-2010, 07:07 PM
DuraGlide's Avatar
DuraGlide
DuraGlide is offline
Just put LEDs on mine and used Biketronics run/turn/brake module. The module is plug in but you will have to custom wire the lights. Mine are wired to the circuit that feeds the turn signals on a stock bike and the module makes them work as run/brake/turn.
Old 03-14-2010, 09:36 AM
turbo38sfi's Avatar
turbo38sfi
Great pictures and writeup, your bike looks sweet. I google'd Native Custom Baggers but looks like their site is down. Can you tell me...did you get your LED stuff with your bags or from a different vendor? They look like 10" strips, which is what I was looking for. Also, what did you do for rub strips on the bottoms of the bags?
Lastly..did you make or buy the end caps for your cut rear fender rail loop? I cut mine last year and haven't found something to fill the holes that looks good.
Old 03-14-2010, 10:25 AM
neano62's Avatar
neano62
neano62 is offline
it a
Check this out! http://www.youtube.com/watch?v=U7ULoBGjG7E
Old 03-14-2010, 10:37 AM
turbo38sfi's Avatar
turbo38sfi
Originally Posted by neano62
Looks good, but I'd want more than 1 LED for visibility for my safety and piece of mind....
Old 03-14-2010, 05:01 PM
mslater741's Avatar
mslater741
mslater741 is offline
his site is down he has a new one coming...my bike is at his shop right now having him install his flush l.e.d.s in a new stretched fender and bags, and front wrap fender....paul just went on facebook today http://www.facebook.com/pages/Native...0539206?ref=nf you should talk to him....wont find a better guy to deal with
Old 03-14-2010, 05:30 PM
mslater741's Avatar
mslater741
should look like this
Old 03-14-2010, 05:32 PM
mslater741's Avatar
mslater741
Quick Reply: Flush mounted LED Tail light questions
