2010 Ultra Limited Heat
Old 03-12-2010, 05:59 AM
woredown's Avatar
woredown
woredown is offline
Default 2010 Ultra Limited Heat
I just picked up a new limited and found the heat off the right side really bad after only a few miles. About 30 miles up the road I stopped for about five minutes to see if something was obviously wrong. Finding nothing, I started up again and continued on my way. No more unusual heat problems for the rest of the 70 mile trip. Any ideas?
Old 03-12-2010, 06:44 AM
Sandcrab's Avatar
Sandcrab
Sandcrab is offline
Default Air cooled
It's air cooled and they rerouted the pipe to make it cooler for your passenger, and made it hotter for you.
Old 03-12-2010, 07:18 AM
Spur56's Avatar
Spur56
Spur56 is offline
Right side where the headpipes comes together is the location of the cat. Probably coming from there.
Old 03-12-2010, 07:42 AM
twodollarbill's Avatar
twodollarbill
twodollarbill is offline
When the weather gets hot out.....take your lowers off.
That's what I do.
Old 03-12-2010, 08:25 AM
ltdan's Avatar
ltdan
ltdan is offline
The heat coming off the cat is miserable. I put a new headpipe and mufflers on to get rid of it. Much better running and sounding now.
Old 03-12-2010, 08:31 AM
Knight2's Avatar
Knight2
Knight2 is offline
My wifes right leg was burning up so I went with the True Duals from Fullsac>>> http://www.fullsac.com/true-dual-kits.html
Not to bad of a job but helped tremendously!
Now the left side is hotter than normal! haha
Not sure if it will install on the 2010s but worth looking into.
Pete
Old 03-12-2010, 08:39 AM
07FLHT's Avatar
07FLHT
07FLHT is offline
And let the SPENDING begin!!
Old 03-12-2010, 09:14 AM
teedubya's Avatar
teedubya
teedubya is offline
I mentioned that when I test rode mine. The salesman who is a personal freind of mine said it would lessen gradually to where it wasn't a factor and it has. I'm satisfied now with 3000 miles plus.
Old 03-12-2010, 09:15 AM
Steelknee57's Avatar
Steelknee57
Steelknee57 is offline
My Limited was really hot the first few miles I rode it. After about 100 miles, it seems to not get as hot.
I think that a brand new engine along with the cat makes it run hot initially.
I've ridden mine in 107 degree heat and I didn't think that it was unbearable, I'm leaving mine stock. I've had Rineharts, a ProPipe, Rush, SuperTrapps, and a FatCat on my other bikes, I'm done with the noise.
Old 03-12-2010, 12:13 PM
'05Train's Avatar
'05Train
'05Train is offline
No issue with heat here either. My right foot gets hotter than my left foot, simply due to the routing of the pipes.
Stop freaking out over the "heat issue" hysteria and enjoy your new bike.
Quick Reply: 2010 Ultra Limited Heat
