Has anyone ever had to replace o-ring on 2008 touring fuel tank quick disconnect?
I have an 2008 flhx and the fuel tank quick disconnect o ring is missing harley says you cant buy just an o ring you have to replace whole peice involves lot of work. compared to just getting an o ring that fits i tried a couple one fits the cavity but thickness was to thick so couldnt get the fitting to go in. So just wondering if anyone has had this same problem and may have found an o ring that works. size metric/standard anything helps...
Thanks
Thanks
