Zumo 660
Zumo 660
I know there are probably a million post of this but I wanted to ask a few simple questions.
1. After installed, will I be able to hear it thru my HD helmet speakers?
2. My passengers helmet?
3. Thru the speakers without helmets?
4. Any benifits for using my Blackberry with it?
5. Can it be wired without using the aux jack port on my Harmon radio?
Going to use the HD dash mount or similiar. 2009 ultra classic.
Thanks
Thanks
I don't have a 660, I have a 550. but the best place is to go to this site and you will learn many things about your new "toy"
http://www.zumoforums.com/
According to specifications, the audio output on the 660 seems to be the same as my 550. Therefore the audio output from the unit needs to be connected to the Harmon radio’s aux jack port with an mp3 cable. You will then be able to hear through the speakers or helmets. Note that the mp3 cable must have male connectors on both ends and aux must be selected on the radio.
5. There is a retro to add another Aux to the back of the radio so you can hook it in inside the fairing. It means getting inside the radio, installing the new port and cutting some wires. If you feel like trying this go here.
