Tour Pack.....I need one..
Hello all,
I have been surfing the web for a few weeks looking for a tour pack and QD for my 08 Roadglide. My bike is Crimson Red and has what appears to be the receptacle for the QD to attach to the bike and that's it.
I want to buy the tour pack that has the "wrap around" back rest and running lights. Will I be able to buy this in matching paint? If not I can get paint codes and have it shot locally. Any tips on where to procure the above or part numbers,options,pics of what you have and where you bought etc. will be greatly appreciated.
Thanks!
Thanks!
Hello all,
I want to buy the tour pack that has the "wrap around" back rest and running lights. Will I be able to buy this in matching paint? Sure; look in the HD accessories catalog or HD's website under "Genuine Motor Accesssories." If not I can get paint codes and have it shot locally. Yes, you can buy HD paint or get PPG codes to repaint an Ultra tour pak or King tour pak; but, most folks don't save much money re-painting tour paks given the costs. Any tips on where to procure the above or part numbers,options,pics of what you have and where you bought etc. will be greatly appreciated. Check Zanotti's and Chicago HD for their prices on what you want; both are 20% off list price HD dealers.
Thanks!
Thanks!
Good luck with your research.
Carl
RR
Also, there are a ton of threads on buying new tour paks. Backrests are sold separately. Also, the lock is sold separately and you will need your bike's key code or VIN to order locks matched to your bike's key. An Ultra tour pak (i.e. a King tour pak with the run/brake light bar installed) will also have holes pre-drilled for mounting speaker pods. Most of this is explained in the listing for the Ultra tour paks in the catalog.
I bought mine on ebay. I had a local paint supplier color match one of my side covers
and I painted it myself. Total cost including backrest, paint, detachable bracket was around $700.00 It came with the large rack, liner and pouches inside. If you want it fast, buy color matched new, but be prepared to pay over twice as much.
You just need the correct mounting hardware for your bike. I got lucky and bought it from a guy that posted it as "buy it now". The same with the detachable bracket and backrest. Just being there at the right time, i guess. It helps that I used to paint cars too. Did the electrical as well. I always wanted more lights on the rear for safety. I haven't taken it off since I installed it...
just slide back the plastic cover on your key, there will be a number stamped there, use that to get matched keys. then you will end up with 4 keys to your bike (2 originals from when you bought the bike, and 2 'spares' with the tourpak) should not have any problem with lost keys then.
