Notices
Belt Adjustment
Old 03-10-2010, 11:45 AM
big_e78's Avatar
big_e78
big_e78 is offline
I think I understand what I was doing now...I had put the tool on the belt directly below the measurement window and pushed up. Am I supposed to put the tool on to the left of the belt guard but then look at the belt through the window?
Old 03-10-2010, 01:20 PM
dstockton's Avatar
dstockton
dstockton is offline
Originally Posted by AlaskaAviator
So Dstockton did you have any problems running a loose belt or at least looser than spec? I believe the spec is to tight.
No, never had any problems and I've put a combined 145,000 miles on 4 big twins since 2003. I probably was a little on the loose side but not by much. If you check a new bike sitting on the showroom floor you can tell they like them tight.
Old 03-10-2010, 04:06 PM
AlaskaAviator's Avatar
AlaskaAviator
AlaskaAviator is offline
I broke a belt last year for no apparent reason and think maybe the belt being banjo string tight might be why. I have a RK here that I am playing with, running the belt why looser than spec. Only have about 2000 miles on it sense I bought it but no problems so far.
Old 03-10-2010, 04:45 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
Buy the bike some cheese to go with the wine
Old 03-10-2010, 09:33 PM
big_e78's Avatar
big_e78
big_e78 is offline
I just adjusted mine with bike on jack. I had a 3/8 reading. After I cinched everything down, I checked again with bike in the air. Still 3/8 inch. Lowered bike onto the jiffy stand. Now it reads 7/8. Why would the manual indicate it could be adjusted either in the air or on the ground? Which reading should I go by?
clap
08-06-2014 12:19 PM
Andyintheshed
05-05-2013 08:14 PM
Reaper22
09-09-2011 08:07 PM
RockDog
06-06-2010 01:49 PM
HDF Tech
08-07-2005 04:25 PM
Quick Reply: Belt Adjustment
